Results 1 to 5 of 5
Thread: Power Plasm 50 Tips
    Default Power Plasm 50 Tips
    I've been looking around and I've seen different design and size tips for the torch.
    Some were listed as "drag tips" and were flat, while others were shaped the same as the ones that came with my PowerPlasma 50.
    Also, any advice on when to use the standoff and when not to?
    Just starting in Aug '10
    Hobart Handler 187
    I know you probably are aware of it, but I am making the comment for the general benefit of anyone reading this.
    There are different torches that appear the same, so be careful not to confuse the tips...as there are different tips for what appear to be the same torch externally.
    Now with that said, there are different tips available apart from what we offer for the torch.
    For dragging, keep amps UNDER 30. The stock con will drag. I've used the long ones with the 4 way hatch marks cut into it. Did not like them, as they actually were worse than the originals...But it could be the material that I was using, being quite dirty.
    So, is it just a manufacturer thing or are some tips designed for other specific purposes?
    Hobart Handler 187
    The way I see it is the cut marks in the tip are for blow back when starting. If you put a tip in contact with the metal a flat tip has no place for the plasma to go before it blow through the metal. by by tip
    Everlast PM256
    Millermatic 180
    Longevity Force Cut 80I
    13" metal lathe
    Small Mill
    ect, ect.
    Any advice on when to use the standoff?
    Hobart Handler 187
  1. tips and nozzle
    By nitris223 in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 11-21-2013, 02:40 AM
  2. Welder Maintenance tips
    By Gary in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 03-18-2011, 01:38 AM
  3. Trouble finding tips
    By Mikenstein in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 08-11-2010, 04:36 PM
  4. Power I-TIG 200 - Tips and comments
    By gclark9460 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 07-01-2010, 12:43 PM
  5. aluminum exhaust tips
    By britstef in forum On Road Fabrication
    Last Post: 03-02-2010, 11:47 PM
