Anyone receive a W300 cooler yet? If so, post a review and pics! Can't wait to get mine up and running. Looks like it 'll be the 25th or so before UPS drops by, dang it!![]()
PowerTig 225LX
PowerCool W300
PowerPlasma 60S
Miller 140 MIG
Power Tig 250 EX
Miller 211 Mig
Hobart Stickmate LX
Victor Torch
It finally got here at 7:30 this evening. I was about to give up on UPS and then beep, beep! It looks like it survived the long trip without any dents or dings yeah!
Attachment 1771Attachment 1770
Power Tig 250 EX
Miller 211 Mig
Hobart Stickmate LX
Victor Torch
Green on green if you know what I mean. Hey Geezer another miracle I hooked up the water and I didn't have any leaksI used some electrical tape to color code the hoses and pad the area around the small hose clamp. I hooked up the blue output to the torch and the red input from the small hose that comes of of the dinse connector. I think that is the correct way.
Attachment 1807Attachment 1808
Power Tig 250 EX
Miller 211 Mig
Hobart Stickmate LX
Victor Torch
I have the 250 ex and the c300 on an everlast cart. I have pics in my gallery for all to see. Had to retro engineer some hose extensions, as no local shops deal with metric hose. Thier loss, 30 bucks at the hardware store and a leak free install. other than a leak inside my torch handle, where feed hose was crimped to the copper line, and a small drip in the quick connect at the machine. I fixed the leak in the hose, but not at the quick connect yet.
When opportunity knocks, most do not recognize it, because it shows up wearing overalls and looking like work!!
Joshua,Tacoma,Wa
24'x48'shop-6/2010
Hobart Handler125w/125cf 75/25-1998-Welds perfect
Power tig250EX-w/300cf argon-2/2011-had 4053 problem, fxed and good as new
Power Cool W300-4/2011-works great after making hoses
Power Plasma 50-4/2011-in for repair
Shop air
Would one of you guys with the W300 do me a huge favor and take a quick measurement of the size of the cooler (Height, Width, Length)? I would greatly appreciate it. I'm getting ready to build a welding cart but the coolers are out of stock at the moment and I want to go ahead and get started.
Thanks a ton,
Chris
Everlast Powertig 200DX
Miller Synchrowave 200
Hobart Handler 210MVP
HTP Microcut 30
How much coolant does the W300 hold? Would one gallon do it or do I need two just to be sure? Plan on using the Miller coolant since it does freeze here.
Victor Oxy-Act
Lincoln AC225 Tombstone
Everlast 250EX & W300 Cooler
Gerald
Millermatic 251
Spectrum 300 Plasma
Everlast PowerTig 250EX
Everlast PowerCool W300
Harris / Victor OA
ProTools Air/Hydraulic Bender
That is funny right there. Given the current education system in the US how many young would know the difference between an Imperial Gallon and a U.S. Gallon. FWIW, Imperial is 10 lbs at 62 degrees F. A U.S. Gallon is 231 cubic inches of volume.
Victor Oxy-Act
Also,
1 Imp gal = 160 oz
1 US gal = 128 oz
rivets
I'm going to give this a bump, no one responded with measurements of the cooler.
if someone who has one could give it a quick measure, I'd appreciate it.
McGuire Irvine
Crow Motor Co.
Lincoln powermig 225 (work)
Measurements as follows:
Left to right: 10"
Front to back of case: 18" plus 1.25" for the quick connects with no hoses pluged in.
Top to bottom: 13.25" from floor to top of case, plus .5" for the filler cap.
Volume: 2 us gallons filled mine perfectly.
There are pictures of mine with a 250 ex on the everlast cart, in my gallery.
Joshua,Tacoma,Wa
24'x48'shop-6/2010
Shop air
