Thread: Project 3, Solar Tig Welding, from Tritium
    The Boonies of Texas
    Default Project 3, Solar Tig Welding, from Tritium
    Below is a pic of 2 razor blades I welded together a few moments ago.
    Ok your asking yourself why am I crowing about a bad looking tig weld on 2 razor blades.
    This weld was done with a 26 series torch, medium gas lens, #8 cup, .040 2% lanthinated tungsten, 7 scfh argon flow, scratch start, 1/2" thick copper backer bar.
    The kicker here is the power source was 2 spare 100 watt solar panels wired in a series.
    Approx 25VDC at 5.25A Torch wired straight polarity.
    I have wanted to try welding with solar panels ever since I put in my array and drew a nice arc one day while wiring them.
    I think the test was very successful given I have less than 36" total tig welding experience to date.
    Now to practice.
    Thurmond
    Miller Bobcat 3 Phase,
    EVERLAST PowerUltra 205P
    Hey,
    I wonder what kind of efficiency you could get by powering the solar panel with the arc flash? You may have created a perpetual machine here. lol.
    There was not much arc flash. I could almost use dark shades for welding with it. My Harbor Freight cheapy helmet works great at 5A though.
    Thurmond
    I saw that "low amp solar TIG" addition to your tag line and meant to ask you about it. Green welding, who'd'a thunk it. Next you'll be welding razor blades with a transformer from a neon sign!
    hmmm... I might have to try this out. you know this more thoroughly than I, but Texas has LOTS of sun. if I could get 20A, I'd be golden
    McGuire Irvine
    Crow Motor Co.
    Lincoln powermig 225 (work)
    20A You need 3, 27V 8A 200 watt panels wired in parallel. See http://sunelec.com/index.php?main_pa...oducts_id=1657
    Thurmond
  1. Any of you guys using Solar Flux B
    Last Post: 06-25-2013, 04:56 AM
  2. Solar Water Heater
    By ShaneJackson in forum Personal Projects (no welder required)
    Last Post: 02-22-2013, 08:58 AM
  3. Project 1 from Tritium, Welding Cart.
    By Tritium in forum Personal Projects (no welder required)
    Last Post: 01-07-2012, 09:12 PM
  4. Project 2, Tractor Seat Stool, from Tritium
    By Tritium in forum Other Custom Fabrications
    Last Post: 06-16-2011, 07:36 PM
  5. Project 1, Third Hand, from Tritium
    Last Post: 06-13-2011, 10:23 PM
