Results 1 to 11 of 11
Thread: Project #10 From Jason: Stripped Lug Bolt.
    Many of the 6cyl or turbo vw's came front and rear disk. On this generation of this car they did integrate the hub and rotor as they did on my Jetta. Later in the years they went to a seperate hub/rotor combo. I replaced the wheel bearings with new ones when I put on the new hub/rotor and did both sides so cooking the old ones a little would have been ok but I was not at the normal shop where the welder was. This was actually at his house so rather than it came to me, I went to it You are right that the only damage to remain was the 2 spots it hit the wheel. Those spots are maybe a dimple if that. I pretty much hit surface and quit. It was crazy how well those 2 wholes worked. After drilling the wholes, I was able to unthread the bolt with a socket hardly grabbing it. I always thread lug bolt in by hand with a socket only and then I pull out the torque wrench to finish them off. I am not sure that this was just over torques but think that maybe they cross-threaded it. Like I said, I could not budge it with a 3 foot fence poll on my breaker bar. I can get the front axle nuts off with just a breaker bar and they are at 195ft/lbs.
  2. Default Next time...
    I had two stuck lug nuts recently on one of my old vehicles that was sitting for a decade.. What I did seeing as my lug nuts had a chrome cover/cap over a steel nut is pop that off with a chisel first. Or at least expose the end of the stud. I borrowed my dad's Milwaukee 500 rpm HD ( like really HD!!) drill and sharpened me up three drill bits starting with maybe 3/16, and another like 3/8" and ending with one that was the same diameter as the outside of the stud's threads. I drilled in maybe an inch and switched bits all the way to the largest. Then another inch again starting with the smallest and on up to largest until you have drilled through the whole of the lug nut which will just fall off then! No damage to the rim that way either! The reason I drilled in an inch at a time was so the drill wasn't sticking very far into the stud and less chance of it snapping off because less chance of a chip binding in the hole. I also had my dad sitting six feet or so away lining up my horizontalness while I lined up the vertical to make sure I was drilling straight in. Also another reason to step it is so the drill bits can cool off and I can spray the hole with some lube
    stuck bolts can be the worst. i reccommend if you deal with bolts alot, go and get a good set of easy-outs. i dont know how many times ive used them, but im sure glad i have them around.
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
    Fixed! You really gotta emphasize the important parts. I've broken my share of midrange quality easy-outs over the years.
    lol, ya i guess i should have stressed the "good" part, sometimes you gotta spend the money and get good quality tools for the job.
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
    man i missed out on my own thread.. I personally do not like easy outs for the simple fact that they can expand the stuck bolt or stud and they tend to break making even more of a problem. Now a bolt extractor that fits around the outside of the head is another story. I have a couple sets of them and they have saved me more than a few times. With this lug bolt, I tried a lug extractor and actually cracked it clear down the side. I would like to assume that this was crossthreaded as I didnt see much rust.
    Default Never sez
    I hope you used never sez when you reinstalled the wheel to keep from dealing with this again.
    Bill
  1. Project 14 from Jason: Scout
    By Jason in forum Welding Repairs
    Last Post: 07-31-2011, 06:48 AM
  2. Project #13 From Jason: Aluminum Catch Can
    By Jason in forum On Road Fabrication
    Last Post: 07-26-2011, 12:04 AM
  3. Project #5 from Jason: Exhaust #2.
    Last Post: 06-13-2011, 06:56 AM
  4. Project 4 from Jason: Shaved VW Decklid.
    Last Post: 06-02-2011, 09:33 PM
  5. Project 1 from Jason: Windshield Leak Fix.
    Last Post: 06-02-2011, 05:05 AM
