So, I ran across a deal on a used Plasma cutter from one of the big guys, so even though I still have full intention on buying EVERLAST, I went ahead and looked up the owner's manual on line, the intent being to see what the output was, and if the machine had pilot arc or not. So as I'm paging through the manual, I run across the section on IGBT handling and replacement. Whaaaat? As I said this Is a major manufacturer, and knowing roughly what the cost of an IGBT module is, I found it hard to believe. That would be like reaching into the glovebox of your new car and reading up on how to remove and replace the engine. Needless to say, I just got done looking at the EVERLAST manual, no IGBT replacement section. Does that mean that failure is less likely? I'm thinking that's a safe bet, just looking for confirmation. Thanks
