So, even though I have yet to be able to order my new 250EX, I figured that it would be fitting to post pics some of the parts I will be using the machine to weld. These are heads off a 1955 panhead
Actually, 1 is a 1956, I'm in the process of locating a correct 1955 front head, and a 1956 rear, to get 2 sets. Notice the chunk missing in the lower right corner. I will have to cut that entire round section off and weld on a replacement piece fron onside and outside the port. This is done and machined off so it can't be seen once the bike is reassembled. Having a stable, focused arc is CRITICAL to successfully restoring these parts. After all the research I've done, I believe that EVERLAST is the solution to this problem, Question I have is if a 200 amp unit will be able to handle this type of work?
