Results 1 to 14 of 14
Thread: Titanium Welding
    Nov 2010
    Thousand Oaks, California
    Default Titanium Welding
    Hello fellow everlast owners, I own a PT250EX. I got the 250EX specifically due to the wide adjustability of the pre and post flow because I wanted to start dabbling in welding titanium. I read anything I could find on the internet about the subject, watched and read what Jody had to say on the subject, as well as many others. I started out with simple fusion lap welds of some .015" equipment tag coupons. I didn't worry about back purgung the weld, since I was ony getting a feel for how the material reacted. To date, this is my best attempt
Name:	improved auto ti weld.JPG
    You can see at the top the white flaky stuff on the backside of a previous weld. This is contamination of the weld due to a lack of an inert atmosphere. Because of the atmospheric contamination, I can rip the weld in half by hand, it is so brittle. One thing I had not heard of until i spoke with Performance was toxicity of welding titaniu and needing a respirator. I have a respirator, but I'm fairly certain it won't fit under my welding hood. I'd like to hear any others experiences with welding titanium, tips, tricks and Mark, a link to your source about the dangers of breathing Ti fumes. I can't find anything on the subject.
    Lincolon SP135+ MIG
    Hypertherm Powermax 600
    It the material is only .015, you will need to purge it regardless as the whole part will turn to oxide. Titanium welding is similar to stainless, but the puddle it is a bit "sticky" (if you dab, the rod can get stuck fairly easily). You need to shield very well.
    Be cautious when welding or grinding as the heat transfer coefficient of titanium is very low and the heat will stay concentrated in a small spot for quite a while. When grinding, the edges will remain very hot and can easily burn skin, even though the main part is rather cool.
    I am not aware of any major toxicity issues with conventional grades of titanium i.e. Commercially Pure or Ti-6-4. There are a wide variety of "weird" titanium alloys, some of which aren't even weldable. You probably don't have any of those tough.
    Nov 2010
    Thanks for the input sportbike. You can definately see the oxidation on the backside of the weld, but the front side stayed protected to varying degrees. Anything outside of the HAZ appears to be fine though, even though it is .015" material. The titanium composition for the ID tags is unknown, but I do have some CP2 material I am starting to play with as well. I also got a couple sticks of Ti filler rod, and ran some beads on the .032" CP2 sheet I have.Attachment 1669
    You can see a few spots where the puddle got a little wide/funky. Those were spots where my hood started rapidly switching between dark and light, and I was basically blinded For reference, I started at the bottom and worked my way up.
    Lincolon SP135+ MIG
    Nov 2010
    Now, plasma cutting titanium is coooooool! For reference, the white sparks you see in fireworks is titanium powder burning. Unfortunately, I don't have any action shots of plasma cutting the ti sheet, but you get twice as many sparks, and they are BRIGHT WHITE. I'll have my wife snap some the next time I cut some. The cutting creates the same oxidation as welding without proper shielding, but it's affected area is much smaller.
    Attachment 1670
    Lincolon SP135+ MIG
    mission viejo CA
    he must be getting confused with stainless make yourself up a purge chamber or run a gas lens with like a #8 cup a trailing cup helps a ton too
    Lincoln precision tig 275
    Miller Syncrowave 350 Tig
    Miller 250 Mig
    old miller 200 Mig
    HF 151 Mig
    HF 100 FC
    Victor Journeyman Oxy/Ace set up
    Bunch of tools of the trade to much to list
    mission viejo CA
    Quote Originally Posted by Adambomb View Post
    when you get them right they will be shinny make sure you using a purge block on the back side cause it will pull the contamination to the front side from the back
    Miller 250 Mig
    old miller 200 Mig
    HF 151 Mig
    HF 100 FC
    mission viejo CA
    also make sure you are wiping it down with acetone prior to welding ti has to be extremly clean
    Miller 250 Mig
    old miller 200 Mig
    HF 151 Mig
    HF 100 FC
    Nov 2010
    Yes wookie, I wipe the metal down with acetone and handle it with nitril gloves to eliminate handling contamination
    Lincolon SP135+ MIG
    Nov 2010
    Performance, any info on the toxicity of titanium welding fumes? Admittedly, I haven't been looking since I was hoping you could fill me in with your source.
    Lincolon SP135+ MIG
    The Boonies of Texas
    Adambomb,
    The comment on toxicity when welding titanium has me puzzled as well. I have read several articles and the only toxicity that is mentioned is during the cleaning process before welding.
    One such article is here: http://www.weldreality.com/Titanium%20Data.htm
    Thurmond
    Miller Bobcat 3 Phase,
    EVERLAST PowerUltra 205P
    Nov 2010
    I know that Mark is a very qualified and experienced welder, and he has cautioned me once over the phone and once in a post about the dangers of titanium welding fumes. I'm not doubting the man, but I also could not find any supporting evidence on the topic. I thought it prudent to start a separate thread to clear up my confusion rather than hijack someone else's
    Lincolon SP135+ MIG
    Would there be any advantage to using a helium mix instead of pure argon?
    Everlast lx225
    Hobart Stickmate LX
    Thermal Arc 400GMS
    10"-22" Grizzly lathe
    Nov 2010
    From what I've read, pure argon is the best shielding gas for titanium, but I would be interested to hear if anyone has tried it; and what their results were compared to straight argon. I do not have the resources at present to make that experiment.
    Lincolon SP135+ MIG
    I worked at a shop called Exotic Metals in Kent, Washington. http://www.exoticmetals.com/
    We worked with a lot of Ti. I think we were running pure Argon. As with all TIG welding your material needs to be as clean as possible but especially for TI. You also need to sheild the backside, or the inside of a pipe using an argon purge. The weld itself should be silver or slightly creamy, if it goes blue on you your not shielding it well enough. The stuffs bloody expensive so don't mess it up!
  1. Welding grade 2 titanium
    By welderdude in forum General Welding Questions
    Last Post: 08-09-2012, 07:50 PM
