I just fired it up and welded with it for the first time... Did some aluminum beads...
First aluminum in a few years. And from a Transformer to an Inverter it's a little weird.
It'll take me some time to get a hang of everything.
My initial thoughts:
Arc starts seem.... Strong? Seems there is a stronger burst of gas upon pressing the pedal. Could seem that way because I'm welding in my basement and it's as quiet as a coffin.....
The arc itself is great. No real problems. Everything works the way it should.
Once I get back into the aluminum groove I anticipate things will get even better.
So other than having to learn to weld aluminum again. And understand all the settings again. My ONLY gripe SO FAR.... The gas fitting on the back of the machine is a barbed fitting. And I can't change it without taking the machine apart. Which I'm not going to do.... So I can't use my old gas lines and regulator AT THE MOMENT....
Once my welds are up to my standards I'll post some up.
Cheers,
Adam
