Results 1 to 20 of 20
Thread: Makita Dry Cut Steel Saw
  1. Default Wish I would have seen this a few weeks ago!
    Sometimes the sun just won't shine on this dog's rear for nuthin'. The local tool store here in the minneapolis area Like a harbor freight with GOOD tools puts closeout items up evert SAT AM. usually a couple big ticket items in the mix. they just sold a Milwaukee version of that saw for $325.00 Didn't have the scratch anyway, but had I saw that thin slice, I woulda found a way. Just out of curiousity, what did the Makita cost?
    Miller Dialarc 250
    ESAB Migmaster250
    Smith Heavy Duty OXY/ACETYLENE outfit
    Arcair gouging set
    I really wish there was a compound miter version of this saw. Its a royal pain in the rear to cut a compound miter with a chop saw. Its sucks when you have to spend half an hour trying to make 1 cut.
    Everlast lx225
    Hobart Stickmate LX
    Thermal Arc 400GMS
    10"-22" Grizzly lathe
    It's not a Makita but I recently picked up a northern tool dry cut for $250.00 shipping included. Fit and finish are excellent and it cuts 4 x 1/4 C channel steel like butter. Dry cut saws are the only way to go. Way better that a fiber blade saw.
    Tim
    Powerplasma 50
    Miller 211 autoset
    Northern industrial dry cut
    Hobart 11 KW gen welder
    AO torch
    Apache Junction, Az
    Evolution makes a compound miter saw that uses a 10" blade.
    Hobart Handler 175
    Hobart Iron Man 230 with spool gun
    Thermal Dynamics Cutmaster 52
    Makita Cold Cut Saw
    Possible future addition:
    Lincoln Invertec V311
    or Miller Dynasty 350
    or ???
    I would like to add to this thread.
    I purchased a Lenox steel cutting blade that is 10" with a 5/8" arbor. Blade cost roughly $90. I used it on my standard Ryobi chop saw from Home Depot. It lasted under 20 cuts. I used the blade to cut a few pieces of pipe, then a couple aluminum fuel rails. After that, the blade made one partial steel cut and then just quit cutting all together.
    I have had people tell me it is because I used a ferrous cutting blade on non ferrous metal. I have had people tell me that is ridiculous and that it is because my standard Ryobi is spinning too fast for that type of blade.
    They make these blades to fit on everyday type saws. We had some 7 1/4" blades of the same type on our milwakee circular saw at work. They worked fine until we tried to cut some rebar. Rebar is a no no.
    Moral of the story? I don't know what it was that messed up my blade, but the answer can be found in the above sentences I typed...
    10.3 @ 134mph 1.5 60' DA 7500ft Bandimere speedway
    http://www.youtube.com/watch?v=leUB4PCv0mU
    Lincoln PT185
    1980's Miller Plasma cutter
    Everlast LX225 here and working well.
    Quote Originally Posted by DiabolicZ View Post
    "I used it on my standard Ryobi chop saw from Home Depot. It lasted under 20 cuts. I used the blade to cut a few pieces of pipe, then a couple aluminum fuel rails. After that, the blade made one partial steel cut and then just quit cutting all together."
    "I have had people tell me it is because I used a ferrous cutting blade on non ferrous metal. I have had people tell me that is ridiculous and that it is because my standard Ryobi is spinning too fast for that type of blade."
    You CANNOT/SHOULD NOT use a standard 'wood use' chop saw for metal by simply changing to a metal type blade.
    The people that told you the 'wood saw' type equipment RPM is too fast for a metal blade are correct.
    Speed is not your friend when dealing with 'hard ' stuff.
    Slow is smooth & smooth is fast...
    -at the job-
    Miller Dynasty 200DX
    Miller Syncrowave 350
    MillerMatic 250 (several)
    Millermatic 350
    Miller Bobcat 250 (Service Truck)
    Lincoln AC225 (many)
    Miller Spectrum 625 Plasma (several)
    -At Home-
    Everlast PP256
    Longevity 256PI
    "Slow is smooth, smooth is fast.."
    hmm think i found my next tool investment
    everlast i-mig 200
    96 gmc extended cab truck 350 rwhp daily driven for 289,000 miles
    88 jeep cherokee custom built by me for me for well everything.someday it'll be finished
    4.6L stroker,dana 44 front, 14 bolt rear, 35"xterrains,soon to come 231/205 doubler
    I just can't figure out why the cold cut chop saw's are so much more money than a abrasive saw. I know the blades are around $100 but $200 for an abrasive and $500 for a cold cut seems ridiculous because they're basically the same just different rpm motor.
    Hobart 140 mig
    Century 300 amp AC stick
    PP256
    Oxy-Accetylene torch
    Milwaukee 14" chop saw
    Evolution compound miter cold cut saw
    Apache Junction, Az
    Quote Originally Posted by Mikeymetal View Post
    ..... Just out of curiousity, what did the Makita cost?
    $430 with free shipping
    Hobart Handler 175
    Makita Cold Cut Saw
    or ???
    Thankyou A/C guy, I think I found my next investment. Here is a video of it.
    http://www.youtube.com/watch?v=gkPAg...eature=related
    Everlast lx225
    Hobart Stickmate LX
    Thermal Arc 400GMS
  1. FS: Makita Charger, Trenton NJ
    By Elantramax1 in forum Buy, Sale or Trade
    Last Post: 01-17-2015, 12:02 AM
  2. Replies: 18
    Last Post: 05-26-2012, 07:00 PM
  3. Cold and hot steel????
    Last Post: 04-11-2012, 03:55 AM
  4. Cratering in steel
    By Tallguy64 in forum General Welding Questions
    Last Post: 04-29-2011, 08:12 PM
