Results 1 to 5 of 5
Thread: Removing a broken bolt - steering box
    Default Removing a broken bolt - steering box
    To give credit where due, I attempted (and succeeded) with this due to watching this Welding Tips and Tricks Video:
    http://www.weldingtipsandtricks.com/...oken-bolt.html
    I've got a 67 Cutlass Supreme Convertible and am spiffing up the engine compartment. I decided to take off the steering box. It's bolted to the frame with 3 bolts. 2 bolts came out whole and 1 didn't.
    Starting Point:
    After removal.
    There's the 3 bolts - 1 good, 1 partially rusted and one in pieces.
    What's left in the steering box.
    Putting on a nut with a washer to weld to the bolt.
    Putting a nut on the other side in hopes that I could put a wrench on both sides.
    After nuts are welded on both sides.
    One snapped off.
    Weld another nut on.
    Yay, the nut on the left is turning!
    Sean M
    Illinois
    I-Tig-200 (March 2012)
    Harbor Freight 90 Amp Flux core Mig
    (Sold this one but I might have picked up some bad habits -->) Harbor Freight 130 Amp lift-start Tig (the red one)
    And here's the end, with the bolt removed! I used a cut off disk in a dremmel to cut the bolt with the nut on the right.
    Sean M
    Illinois
    Cool. Nice job. Jody is absolutely right. With the right TIG welder you can put a nice precise arc where you want. Pretty handy stuff. Thanks for posting the pictures!
    Very nice.
    putting a wrench on both sides is not too bad of an idea... too bad my broken bolts do not stick out on both sides 99.9% of the time
  1. Removing the Ram Slop from a Harbor Freight 20 Ton Press
    Last Post: 08-11-2017, 03:50 PM
  2. Steering 14 Bolt
    By GFab70 in forum Off Road Fabrication
    Last Post: 12-04-2015, 04:50 PM
  3. Removing Mill Scale from Hot Rolled Steel?
    By Spike in forum General Welding Questions
    Last Post: 02-20-2013, 02:49 AM
  4. luvin my Steering wheel
    By azlo in forum On Road Fabrication
    Last Post: 12-27-2012, 04:00 AM
  5. Removing the MIG torch WP-18 shield nozzle
    By everlastsupport in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 07-26-2009, 04:24 PM
