Thread: Tip for Multi-process machine users
    Default Tip for Multi-process machine users
    This suggestion is for infrequent users, like me, to help remind them which leads go where. Most useful after doing DCEN stick welding, then switching back to TIG or Plasma. Put tags on the leads. I did this after I first got my PP256 and was checking out all the functions. After doing some stick welding, switched to check-out Plasma cutting and didn't change the work clamp connection. Needless to say, the Plasma torch DID NOT like the backwards polarity. The labels will make sure that can't happen again. Beats digging outClick image for larger version.
ID:	1011 the manual to check your memory.
    Tony
    Everlast PowerPro 256
    AC225 "Tombstone"
    HF 20 ton press
    Rotary 9000# two-post
    And remember not to trip over all those cables!!!
    great tip!
    300whp FWD 94 Celica
    Orlando, Florida
    I was wondering about the simplicity of switching cables on these units and this a great idea.
    Peter
    Great Idea Tony! Thanks!
    http://projectoldwing.com
    wruehl@hotmail.com
    Active Ironbutt Member.
    Apr 2011
    Sasktachewan, Canada
    I like simple easy to use ideas. Nice one Tony
    Attitude Determines Altitude
  1. is multi process for me?
    By drthunder33 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 01-23-2015, 12:33 AM
  2. Why is there only Multi Process or MIG/TIG/Stick?
    By jp2code in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 02-21-2012, 04:50 PM
  3. Multi Process and torch cooler
    By Tony_F in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 04-23-2010, 01:18 PM
  4. pure plasma or multi process?
    By alexm in forum General Welder Questions
    Last Post: 01-27-2010, 02:43 PM
