Results 1 to 11 of 11
Thread: shop made serpentine belt tool
    Default shop made serpentine belt tool
    seen thes belt tools before but did not want to spend the money although it would of been cheaper to buy one but
    made these tinkering around the shop need to change a belt and got tired of having to interlock two wrenches together and fight with the small area in the sons car to get down in there.
    just thought I would share it with yall.
Name:	shop made tools 002.jpg
ID:	675   Click image for larger version.
Name:	shop made tools 006.jpg
ID:	676   Click image for larger version.
Name:	shop made tools 008.jpg
    Nice idea, certainly a handy gaget if you need to replace the belt, been there, done that, myself and it ain't no fun, those dam belts always break at night during a rainstorm or at -30 in a blizzard, at least mine use to, Now a days I get them replaced at the first sign of wear.
    Jan 2010
    Chugiak , Alaska
    I really could have used that a while back working on my sons Caviler. What did you use for the square? Looks like part of an old ratchet or break over bar.
    ____
    Ray
    support@everlastalaska.com
    www.everlastalaska.com
    877-755-9353 X207
    Quote Originally Posted by Ray View Post
    Hi Guy’s
    I guess It would have been a good idea if I had elaborated a lil more on what I used as materials.
    28 inch long flat strap 3/16” thick 1” wide, round the edges at both end’s for desired look
    Take a cheap short 3/8” or ½” extension and cut the socket lug off roughly a ¼” above the lug
    Put flat strap in drill press and drill a hole on one end roughly a ½” from the end and try to center it but you will have to use your judgment as for your center depending if you use a ½” or 3/8” lug drill the hole slightly smaller so you can tap the lug in to place as straight you should have a slight dish on back side of hole to TiG or use MiG weld back side of lug in to place using a sort of spot weld puddle filling, Using MiG is nice and quick and leaves a nice little dimple and should not have to do any grinding after.
    As for a coating on the handle you can grind some small dips on each side about 1-¾’s of an inch long
    Or you can leave it flat then I used a ¾” heat shrink for a sort of anti slipping grip works real nice.
    Really simple to make and works great.
    now weld a plug at the other end that will accept a 7/8 ratchet wrench and you hve one of the nicest belt tools out there. I use the gear wrench one and the only belt I have not been able to remove with it is from a mini cooper.
    Jul 2010
    Port Saint Lucie , Florida
    Just wondering, The last time I was at sears to get parts for a broken ratchet they are like .01 cent so they dont have to change them out , but I do not remember if the 3/8 square end comes with it? But that would be a cheap alternative if it comes with it..
    Gary
    you can use a pice of 3/8 keystock also or square cold roll, that's what I used on mine cause I didn't have anything else handy... at 3 am.... at -30 degrees.... in a blizzard....after a mechanic told me it was worn out....
    ...*.......-'. \..\__/
    ... /......... _/
    ...|.... /_\'
    ....\....\_/
    Harbor Freight has it for $14 on sale, I'll buy that one and do the required mods.
    I am out trying to 'find myself'. If I should wander back while I am gone, please tell me to sit quietly and wait for myself to return.
    LOTS of scuba and vintage scuba equipment [I'm Always willing to trade or buy the stuff you think is too old to use]
    Smithy XLT Mill/lathe [It was easier to learn than I thought, I'm no pro, but I can make a bearing hanger]
    Everlast PP256
    gotta love homemade tools.
    sometimes, its the only way to get the job done!
    300whp FWD 94 Celica
    HF today. $247 later...I have a serpentine tool. It's all I went in for....
    Everlast PP256
    ^^ hahahaha aint that a bit%h?!?!
    go in for 10$ worth of stuff...come out with 250$ worth...yup, sounds about right!
  1. Brass And Copper Belt Buckles Project 1
    By cbmkr in forum Metal Art
    Last Post: 09-11-2013, 06:50 AM
  2. Project From EmptyNester - Belt "guide" for hovercraft
    Last Post: 10-10-2012, 05:01 AM
  3. Project #1 posixPilot, Cat: Custom Welded Shop, Mobile Tool Base
    By posixPilot in forum Other Custom Fabrications
    Last Post: 04-02-2012, 03:49 PM
  4. Very first weld I've ever made
    By craig in forum General Welder Questions
    Last Post: 11-16-2011, 01:08 AM
  5. Replica naval cannon and nautical belt buckle
    By jtybt in forum Hobyist Projects
    Last Post: 06-21-2011, 11:15 AM
