Results 1 to 3 of 3
Thread: 4130 BMX bicycle bottom up build
    Default 4130 BMX bicycle bottom up build
    Here is my bmx build. It was a fun build, figuring out the jig was a blast. I look forward to making many more bicycles.
ID:	621   Click image for larger version.
Name:	rear triangle in jig.jpg
ID:	622   Click image for larger version.
Name:	chainstay fit up.jpg
ID:	623   Click image for larger version.
Name:	fun gusset.jpg
ID:	624   Click image for larger version.
Name:	freshly welded still in the jig.jpg
    Nice build, it's easy to see you have talent. I just bought a JD notch master for notching some tubes, what material did you use for your build.
    Thanks,
    The material is 4130 bought at an avataion supplier, Aircraft Spruce. I have used tube notchers and they work great. I made a v block for my tool post and I cut the tubing on my lathe using my chuck to turn a hole saw at low speed. I can cut huge angles and offsets easily.
  1. Monday morning quarterback: bicycle weld
    By DaveO in forum General Welder Questions
    Last Post: 04-08-2013, 07:04 PM
  2. Filler metal selection for welding mild steel and 4130 tube
    By hooda in forum General Welding Questions
    Last Post: 03-21-2013, 07:38 PM
  3. Foot Pedal Bottom Pad
    By NRM in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 08-22-2012, 10:46 PM
  4. Has anyone built a bicycle before, from scratch?
    Last Post: 05-08-2012, 01:00 PM
  5. Replies: 7
    Last Post: 10-09-2011, 07:30 PM
