My new PowerPlasma is on the way.....Yeah
Just to liven things up around here.....
My new PowerPlasma 70 is on order. I hope to maybe get it set up this weekend. While I wait I'm setting up my air dryer and getting set to pull some 10 gauge wire for a new 220V circuit in my shop.
I've always had a dryer and I live in a pretty dry area but figured adding some copper pipe and a desiccant dryer and an oil free line to my system would be a good idea for the cutter. I can't recommend it yet but I am hoping this unit from Harbor Freight will do the deed, can't beat the price. Now if I can only find my soldering torch.
http://www.harborfreight.com/cpi/cta...emnumber=97686
Alex and the other guys at Everlast were very patient with all my questions (you can see a sample of them scattered here on the forum) I had a really hard time settling on the PP70. My cutting needs run more to the light stuff so I figured the PP50 was the way to go. That and I kinda liked the non-HF start due to my having CNC equipment in the vicinity.....I'll still worry about that until I see there is not a problem, but I also think the HF start is better for cutting expanded metals which is important to me. Once I committed to the bigger HF unit then I had to decide which one....each step gives you more cutting power and all probably exceed my need. I decided I liked the P-80 torch better because it seems to have more flexible nozzle setup (wish it was a more modern torch with swirl technology but I understand that may be coming soon, maybe I will be ready for an upgrade by then)....so HF + P-80 meant either 70 or 80 and well I figured the 80 was just overkill but for the nominal price difference it was a hard decision since we all know more power is always better......:)
Anyway back to putting the shop in order..I'll post some pictures and initial impressions once the cutter arrives.
Darren
Darn, no Joy in Plasma town this Christmas Eve.....
Well my the replacement for my shiny green monster arrived today....
Just one week and a day since I first placed the order....The replacement was apparently shipped on Tuesday, probably even before I got the return unit on it's way back to Everlast...good service there!
Been kinda busy today, with it being Christmas Eve and all, but I took some time to inspect and hook up the new PP70. I again noted no significant damage to the shipping carton and externally the unit appears fine. I did note the middle of one yellow wire kinda poking through the vent grill on the left side of the unit but it doesn't appear to be damaged, just something that shifted a bit, I carefully poked it back it inside with a plastic tool.
I hooked the PP70 up to the air supply and power turned it way down to 25A and pulled the trigger.....I hear the valve open the air starts to flow but no pilot arc strikes. I tried several times with various air pressures from 60 to about 80. I tried just holding the torch to the work piece to see if anything would just but nothing. I checked the fuse and it is good. I get an amp display this time but there no buzz from inside the unit that I associate with the HF starter. The old unit buzzed constantly or for the short time it worked when the arc was started but this one is silent. I can only guess and hope maybe the internal gap setting is too wide or something simple like that, but I have no idea what the gap should be...that first unit had a really wide gap probably over an 1/8 inch and had no problem zapping across that.
I did note that the torch at had been test fired at least there was quite noticeable burning on the electrode and nozzle, I had not noted that on the previous unit....I took pictures.
I don't suppose any of the support guys are spending the 24th online but if you are out there I would really like to get this going I have projects to get to and time off scheduled to do them.
Darren
Wow Tech support on Christmas
I spoke with Mike on Christmas day and he talked me through checking the unit over...now that is service.
I expect maybe something might have happened in final assembly of the cover after initial testing (the unit has an october test label on it), to me that would account for the odd screw and maybe the tweaked gap point, they are relatively close to each other. I am still working to discover the reason I can't seem make a decent cut, possibly something else was tweaked that I just don't see, or maybe it is me, but I don't know what I might be doing wrong. I am going to double check things even though a replacement unit is going out on Monday, again pretty impressive on the part of Everlast to make things right...and I expect now that the shipping season has past it might have a little smoother ride too.
Overall, while I am personally a bit disappointed I could not get to work right away, I feel like Everlast has been extremely responsive and reasonable which is all I ask. Once I get everything working as it should, I would recommend Everlast to a friend and when I have the need, time and money I would consider a nice green welding or generating unit. Every maker I have ever worked with has these sorts of issues from time to time and none have made more of an effort to correct things or provided better or more timely support than Everlast.
