I am trying to weld aluminum. Running @ 150 amps. 1/8 thick. 3/32 rod, 1/8 2 % thor tungsten.
Everytime, the electorde gets a ball at the end of it. Or it blows the tip off. What am I doing wrong?
you are welding in ac mode ,were do you have you ac balance set and the amps are to hi for thin stuff . try 80 to 90 amps to start out-- 150 amps is what i use to start out when welding a thick aluminum head
The AC balance was at about 12' o clock. I will turn the heat down. I read I need to turn the AC balance all the way counter clockwise? Is that correct?
yes i always have my balance almost at 9 o clock pointing to the left . on my 250 if i go past 12 o clock it burn my electrode were do you have your post flow , ac freq at and are you using the pulse on or off . forgot are you using the pedal or just the torch by itself
watch out,
on a 200DX all the way down is 30%.
on a 250EX all the way down is 10%.
so yea, on a 200DX I would run it all the way down for most stuff.
I have been using my foot pedal. I tried using the switch on the torch. Screw that.
Just ran a few more beads. Looking better. It's a steep learning curve. I am catching on though.
Thanks for the help.
I found out when i started welding aluminum i started out low on amps then worked to higher amps if needed that way you don't fry your tungsten or burn threw your aluminum . also make sure your aluminum is nice and clean before welding
you want your tungsten to ball up on the end when welding aluminum
Mine don't ball at the end . http://www.thefabricator.com/article...ten-electrodes
The ball on the end is normal. Drop the power down for sure (see Rods post), 150 is HOT unless you use the pedal and 1/2 the amps. Make sure you have straight argon too. Any co2 will toast the tungsten. Run the balance at 30% (see Rays post). Clamp is +. Gas flow at 8-10lp should be plenty. That is about it. Are you running 4043 or 5356?
Yesterday, did a measure once cut once, weld it back, grind and cut again... It was 1/8th aluminum angle 50-60 amps will do it for you, 70 if on the pedal should be fine.
So, hang on a second, are you saying that a balled up tungsten is actually desirable when welding aluminum? Or are you saying that a balled up tungsten is the normal result of too many amps? I'm new to TIGing, and I was planning on trying some Al next week some time.
Mike
its normal for the end to ball up, nothing to worry about
if pure tungsten yes ball that was the rule on older tig machines , not on the newer sinc pulse wave welders since they don't use pure tungsten. rule for new machines electrode pointed for lower amps and higher amps pointed and truncated tip . that means grind to point then make tip flat on end about .010 - 030 . me myself i just knock the point off about no more than .010 . for what i weld and in a tight area i have to have a point so the heat and arc go exactly were i want it to go ,for example welding aluminum heads inside a intake or exhaust ports that has a crack or a crack between the valve seats ,cant have the arc dancing all around in a tight area
The ball is pretty much something you will see with the 2% thoriated. Nothing to worry about as long as it is not bigger than the electrode :). Grind them to a point and I tap the end to flatten the point.
When I was using thoriated for AC and a machine stuck with 50/50 balance, I used to grind the tungsten to a fine point. Then I'd put it in the torch, and put the machine on DC+ on purpose. Then light up on some clean metal, and slow ramp up the current and intentionally burn back the electrode until I had a nice cone shape with a rounded off tip. This worked a lot nicer than letting it ball on its own, which can sometimes cause it to form weird shapes and patterns on the tip. You can change the size of the balling based on how much current you are going to use.
Not sure you can do that with an Everlast welder though, can you?
http://i142.photobucket.com/albums/r...506_100500.jpg
I know these look like crap. But here is 30 minutes of learning to weld. First I had to learn how not to blow the tip of the tungsten off. Then, heat issues are another thing I am working on. But these beads are the first time I have ever used a TIG welder.
And one thing that was weird for me is how loud the HF noise is when burning a rod. Crazy.
AC freq or HF? If AC frequency, turn it a little more clockwise.
Today I went and bought some pure tungsten. Bad idea. It welds like crap. Going back to 2%.
Haha, yeah, for what you are doing, forget pure tungsten even exists. Stick to one of the alloys. That's why there are alloys to start with, they drastically increase current capacity. I personally use 2% Ceriated. Lots of people, if not most people, swear by lanthanated. One of these days I'll get around to trying it. For me though, ceriated works great on AC. Now... on to your practice.
On a piece like that, at your current stage, don't even bother moving across it width wise. It's just going to blow out on you until you get more used to aluminum soaking up heat and having to back way off the foot pedal to keep with it. I'd stick to running long wise. There are two sections in there of pretty good looking beads. However, both of those started off too cold. Then, as the material started to heat up, the bead started to lay out nicely. Then, as you got close to the edge, it blew out on you. You may want to go without filler for a little while. It's good to play around just making a puddle and traveling along with it and trying to keep a constant width, so you can see how the aluminum reacts in different situations.
Also, for the loudness of the arc in AC mode, the amount of gas flow you have will directly effect this. Having a lot of gas flow will accentuate the sound and make it much louder. You might be able to get away with turning your flow down some.
I posed the question about the different rods. 2% Lanthanated seems to be about the best for general purpose. Works great on Aluminum. Everyone has their favorite but this one seemed to top the list. Not sure if you tried it. At least put it on your buy list for next time.
