Originally Posted by
performance
Hesstx,
Your tone does seem a little hostile...maybe I am reading it wrong. That's fine, but you need to know there are reasons we are more expensive.
Look closer and you'll find more differences if you know what you are looking for, mainly in quality of components. There are at least two coolers produced that look the same...and yes water coolers come from several different factories...Many of the factories are not vertically integrated like they are here in the US...But there are two grades of the same cooler in appearance but with differences in construction. We use the more expensive grade of components. I won't go into all what they are, but there is a difference. It goes back to the basic construction and materials used and where. The cooler you have sounds as if its also isn't grounded and I would consider it a risk unless you grounded it properly when you rewired it. We can sell a cheaper cooler too, but we don't. Time will tell in the years to come. You won't find many if any complaints about ours.
The Everlast Coolers come with quick connect couplers and the nipples for the torch water lines as well that are color coded. That's worth nearly half of the difference you paid right there. We send the WP 18 torch out so people can hook to an existing cooler and adapt it as needed IF they wish just as you have done. The torches we send out are typically torches that people are ordering for our units...It means if they are ordering a watercooled torch from us then they usually have both one of our coolers and a welder in which case they have likely used the fittings with the cooler for their 18 series torch. Or if they don't then nothing lost and no frustration from the customer trying to search around for the right fittings.
So to sum up what I am saying: If you are interested in the lowest price, great. I hope the black cooler works for you...just don't use it in the sun since you'll likely end up with a water heater instead of a cooler. But if you want a better quality, then you'll have to pay for it. We don't charge that much to begin with, but someone is always going to provide a similar but cheaper version of something no matter the price.
