When should we coordinate the shipment of our 250ext welders back to you for replacement?
They'll be rounded up systematically, of those still left out there... Oleg's words were that this shouldn't be a worry for customers of the 250ext (old).
Looking forward to getting mine :)
Sounds like there is a plan to fix the small issues to.
Any more updates?
A quick update from here, as I am off to get to work.
I've really only done a couple small aluminum projects. On steel, perfect. No start issues I can see. It's lot like the 210EXT, smooth starts.
I have not ran any real high amps with it yet (but it has the same driver board/finals as the 250EX so I'm sure that's all good), but I have thick plate for that test if needed. Also, we have not really pushed a lot of aluminum work through it either. Busy, so I just that is a good thing.
Anything anyone wants tested from the old model, if I can do it? Mark has one I believe as well. I know Mark beat it up on the low amps start-up for both steel and aluminum.
I just watched the Demo of this welder on youtube and I was really impressed with the smooth low amp arc starts! Smooth as silk! Those digital invert machines are soooo nice!
The units are IN. All should be shipped out by Friday...minus the few things we discussed earlier. They will spot check a few boxes though, so don't panic, if you get one that has been retaped, to see if anything has changed from our earlier determinations about what is missing or changed.
PLEASE, contact Oleg today though and reconfirm shipping addresses etc before he ships. We know some of the shipping addresses have changed.
We'll be rounding up the remaining old units of the 250exts shortly.
Alright !!! :D
That's real good news, can't wait to light up!
Now Waiting on the Stoop in Kent
Jim
The timing of this couldn't be more perfect. Earlier would have helped but it is still going to arrive just in time for my needs. :)
I want my...... I want my E X T..... :)
Taking your reference one more step...
we gotta weld aluminum castings
copper tubing, magnesium
we got to weld these triangle wave forms
We got to weld these stainless turbos
Mine will be here tomorrow, according to UPS!!!
I called and spoke to Alex. When it shipped, I got a notification via email. Says it will be here today.
Looks like they are getting out to everyone. Guys, hang in there, it will be worth the wait.
Used it today testing with it, to do a number of products for a customer.
I has a lot of features, and thank God I can save the settings. Setting #5 is for this one.
Attachment 10948
Attachment 10949
This is a nice update to watch while waiting for them to arrive. Thanks to Tim, well done. (Now I know where my machine has been!) Jim
http://www.youtube.com/watch?feature...&v=bkuXKsls3e8
It's finally here folks... Here's a little eye candy for you!
http://img.tapatalk.com/d/13/10/12/unasysa6.jpghttp://img.tapatalk.com/d/13/10/12/ajehatun.jpghttp://img.tapatalk.com/d/13/10/12/gu9ede5u.jpghttp://img.tapatalk.com/d/13/10/12/6ejy5ume.jpghttp://img.tapatalk.com/d/13/10/12/hejujy6u.jpghttp://img.tapatalk.com/d/13/10/12/gada3esa.jpghttp://img.tapatalk.com/d/13/10/12/hy9uqahy.jpghttp://img.tapatalk.com/d/13/10/12/vugu8u8y.jpghttp://img.tapatalk.com/d/13/10/12/beru2yvy.jpghttp://img.tapatalk.com/d/13/10/12/asu7etuz.jpg
And the last one of the power cord... Measures at 6'8"http://img.tapatalk.com/d/13/10/12/7ezyqejy.jpg
Yeah, you nailed it... I was surprised by how well UPS did with the box, but the packaging was very nice anyway. The foot pedal is the new style, which should be good. As for laying a bead, unfortunately, I am getting my house painted tomorrow, so due to procrastination, I won't be able to play tonight. And I'm gone the next two days for work... So this weekend is shot! We'll have to wait until next week! Sorry folks!
I was under the imression that it had a plug for the cooler but when I unboxed mine, I also noticed that it did not have one. I also was very impressed with the handling from UPS other than they left it at the garage door even though I WAS home when it arrived. No notification from them.. I heard the truck pull away so I decided to go check as they often just drop things at the garage and leave it.. :mad:
I will have to post some pictures later but I am also unable to test it right away.. Maybe tomorrow or sometime this week.
As to the ground, I assume that the new one will be sent with the torch package later? Can someone confirm this or are we not going to get the new style like Tim showed? I am pumped over the new pedal and regulator though..
Waiting and waiting and waiting and waiting, got the machine but now no time to use it. Likes buying a new car and flying away on a holiday the day you get it. Not me when mine comes the job is waiting for it.
It's a Great day! Mine arrived late this afternoon:) Here are some first impressions:
UPS did fine, I was very anxious about it getting here intact, but it looked great! The box was nearly perfect and was banded with 4 white plastic straps.
Accessories are what we have been told to expect. 3-series rigid water-cooled torch, and old-style work clamp, but the pedal and stick stinger are the new pieces. Flow meter is the new style, and looks good. The torch and denim zippered cover are real nice, although I will probably use my old EXT torch until the correct gear shows up.
The machine looks real good. Out back, it comes with a nice length of 10/4 primary cable that's over 6' long, no outlet for cooler on this one either. The front bezel, panel and clear cover are really cool. This machine is nice!
Much smaller than the Legacy 250EXT. Actually quieter than the old one, too. Measured 69dB at 1 foot from front grille, and 74dB at 1 foot from center of rear grille.
Not much time tonight, but ran a few 1/8" 6010 and 7018, very nice. Need to play with the stick settings more, we have a lot of control over arc starts and arc force now. Tried VRD (without knowing it) mode, and it runs a little different than straight stick. I need more time to understand the differences. I don't require myself to operate it as a VRD, but I would like to understand if there are other benefits.
I have a great first impression of this machine, and will get into the TIG functions on Tuesday. Will post some pix next time.
Machine is beautiful, and its operation looks great so far. Thanks Oleg and Mark, et al for sticking with it and getting us EXT Pioneers what looks to be a very suitable solution.
Finally Up and Running in Kent!
Jim
I'm still waiting for a phone call. Guess I will have to make the call.
Just fired up the 255 EXT. This is night and day compared to the 250 EXT. Alex and the team really did a good job providing a great welder.
I was able to run some AC and DC GTAW with some AC pulse on 1/4 inch aluminum. Worked great and the initiation of the arc in DC is extremely crisp. The HF start is much cleaner and no violent like the 250 EXT.
I ran some 1/8 inch 7018, this is again night and day performance over the 250 EXT.
I am very pleased with the new welder.
My 255EXT arrived today! I'm pretty excited. This has been a long time in the waiting. (It's actually from winning a Forum contest a while back... initially opted for a 250EXT and waited for that, but missed out on that, so now here I am with a new 255EXT :) Thanks Oleg!)
Although I haven't powered it up yet, so far I'm glad I held out for it. My 2007 Everlast Super200P (which I have put through a lot) is still a competent machine. I probably wouldn't have bought a new machine if I didn't win it - I would have just kept using the '07 Everlast. But I certainly can't complain about winning a new machine!
Observations:
* The Everlast machine packaging is really amazing now, compared to how it used to be. There was a gouge in the corner of the cardboard box from UPS, but it did not penetrate the very high quality and thick foam padding to make it to the machine.
Attachment 10969 Attachment 10970
* The machine is really great looking.
Attachment 10971 Attachment 10968
* The bare machine weighs 61 lbs.
* There is a 2-conductor "solid state device" of some sort where I expect the spark gap would usually be. (Aside from that the arc starting circuit looks typical tesla coil circuit - no transistor) See picture (white cylindrical thing at right with a lead coming out of each end):
Attachment 10972
* On the back, near the top on the side opposite of the on/off switch, there is an area where it looks like a cooler power plug could go. (Two pre-drilled holes with what looks like room for mounting a receptacle on the sheetmetal here, and easy taps to the power switch/circuit breaker on the inside of the machine nearby.)
Attachment 10965
* The new footpedal seems to have an improved (more sophisticated) linkage to the potentiometer by the way, that allows the pedal to move the first bit without moving the potentiometers so that the microswitch can initiate the arc before rotating the potentiometer. I imaging that this may allow "feathering down the throttle" to the minimum amps... (Assuming the pot is indexed/adjusted properly, of course, but that can likely be fixed if it's not.) I can't wait to try it!
Attachment 10964
The accessories mine arrived with were:
* 14.5' long new-style footpedal (So far looks pretty sweet... can't wait to give it a try!)
* WP-18 style rigid TIG torch (labeled "SR-18")with 13' long, outerbraided-style hoses inside. A nice, zippered denim-type cable cover. Handle diameter = 1-1/16". Includes a zip-tied on switch. Hose diameters inside were 5/16" (for the two smaller hoses) and 1/2" (for the single larger hose).
* sheetmetal ground clamp with 9.5' long cable (not the brass tweco-style clamp, but the plated sheetmetal, albeit a bit better quality than I was expecting for this style!)
* spring-clamp style stick electrode holder with 9.5' long cable
* a very good looking, new-style brass argon regulator (I've had great results with this style from other sources)
Attachment 10975
I decided I'm going to go through mine and give it some TLC before I fired up, because I figure I have more incentive than the factory assembler/worker to make it all perfect. (This philosophy has worked well for my 2007 Super200P... still firing a reliable TIG arc today). I found and fixed some minor fixable problems so far when going through the machine already - including:
* footpedal arrived with the top moving platform part off one of the pivots pins. It was fairly easy to just snap it back into position, although I don't know if it will be all ready to go after doing just that (may need adjusting to optimize its range... we'll see)
* The adhesive-affixed laminate over the front control panel had a pretty annoying looking "wrinkle", right over the "Normal/AC Easy/DC Easy" button (and it seems like it may have made that button difficult to press):
Attachment 10973
To fix that, I used a hairdryer to warm up the affected region, peeled the laminate away from the corner over the area, and applied it back on smoothly. I think the top two screws going through the control panel (which are also structural ones for supporting the welder components) seem to grab at the laminate and want to twist it when tightening, so I think I'll trim the laminate away around there to make clearance for the screw heads. I don't want to leave the screws loose here since they're structural for keeping the machine rigid. Unwrinkled:
Attachment 10974
After I'm done giving my 255EXT its initial TLC, I'll probably try to adapt my CK-Trimline 210 aircooled torch to it to try it out. (Eventually I'll want to get a watercooler, but I haven't figured that out yet, but I know it will be switched by the machine ;) ). I'm thinking I may also need to put a longer electric cord on this machine. (I have a 25' extension added onto my Super200P's factory ~6' long cable and I really appreciate the extra length, although this is only 12 gauge, which may not be quite adequate for the 255EXT.)
Love to hear that kind of praise, for the new machine. Thanks for the quick feedback.
Thanks for the great first impression and all the photos. That looks like a gas discharge tube, (basically an enclosed spark gap) they are used for over voltage protection on many things. Can't wait for your performance review. Pretty short list of build quality issues, that's always a good sign.
I like your philosophy of; "Don't turn it on, take it apart!" ;)
Sounds like it was all worth the wait. Truly a flagship product. Good to hear the low amp starts are smooth.
I try to fire up products before tweaking. I never know if UPS did something terminal to the product that I didn't notice. I don't want to spend time on something and then find out it needs to be returned or repaired. I've been there and done that a few times.
I see ever one so far is very happy with their new 255EXt can't wait till Canada get there's next month or the first of Dec. just in time, I will be get back from my holidays one present after another. Hope to see pictures of the welding they are doing.
Thank you all guys who waited and didn't give up :)
we did all we could to make this the flagship everlast unit
enjoy the welders !
I bought and used a 25' long 10-gauge power extension cord (http://www.harborfreight.com/25-ft-1...ord-66495.html) and a plug (http://www.lowes.com/pd_246879-1571-...amp&facetInfo=) to extend the 255EXT's power cord:
Attachment 10987
Then I did a quickie argon connection to it to try a quick, low-temp arc (with the WP-18 that came with it) and the footpedal out. The good news is that it's alive! Here it is next to my 2007 Everlast Super200P ("old faithful" :cool: ):
Attachment 10989
It pretty much worked as expected for its first arcs, which were short and in 1/16" aluminum:
Attachment 10988
I really need to get my higher power aircooled torch adapted to it (or get some watercooling solution figured out) before I can really explore anything more than a very small fraction of what this machine has to offer, though.
There were a few minor tweaks/improvements I made to this machine before I fired it up - but I don't want to clutter this thread with too many of those details, unless a lot of people are interested in them. (Or, maybe I'll start my own thread so I don't clutter this one up too much. :) ) I do have a question, though: is this connector, which I salvaged from a PC power supply, the same style that Everlast uses on the back of the 250EX for the watercooler? (If it is, I'm thinking of adding it to my 250EXT)
Attachment 10991
No, you need the opposite gender for an outlet. Having live pins like that would not be good.
http://arlin.com.au/assets/media/pro...crew_mount.JPG
Find an older PC supply, and it will have one of these to plug the monitor into.
