Any luck finding those settings? Do you use different settings for 5356?
The forum has that jumping cursor problem again where midway through typing a sentence the cursor jumps to the line above.
I just.got.back.My.space.does.not.work?WillmailLeon. .Trying to get it back were I had it.But.goingfast
05-12-2017, 11:00 PM
Kempy
Quote:
Originally Posted by zoama
Thank you for the tips but 99% of my spool gun work is .090 aluminum sheet and tube. I need pulse to prevent heat buildup from burning through.
When I weld .100 aluminum I still use 4043 3/64" (.047) wire at around 16 to 17 Volts 230 to 250 amps/wire argon 20 to 22 CFM and it is close to spray welding. The pulse is nice but I don't have that feature.
05-18-2017, 10:37 PM
zoama
Quote:
Originally Posted by everlastsupport
I will get the starting range my son uses. We do 4043 all the time and look great. No spatter. We have never got it to spray with aluminum either.
Any new developments?
06-11-2017, 04:12 PM
everlastsupport
He said the main thing is he has to run the AMP/speed knob all the way up. Also little over 1/4" is all he can do wit 4043 .030
