Originally Posted by
Rambozo
From the second video, it's pretty clear that you have the right arc length and the torch is steady. Things start off ok, then without anything changing, the arc becomes unstable, and the sputtering starts.
The one thing you can check is the HF point gap, if your model has the open point system. Not likely to have any bearing on your problem, but it's something to eliminate from the troubleshooting. Another thing that is always good to check are the board to board interconnects. Re-seat the connections to make sure nothing was shaken loose during shipping.
