I have it set to 0 Zero it is the drive motor wheels can't keep the wire at a constant speed, the motor needs to be bigger or a gear box to keep the wheels at a constant set speed.
If the drive motor is varying in speed, I'd check the voltage input for stability under load.
Bob, I looked up the company that builds the boat you talk about, they have been in business since 1960. Of course, we know they didn't have the equipment we have today back then. How do you suppose they did those welds over 50 years ago? My guess is the same way as they have always - nothing fancy required - turn the volts down and stitch.
I know its not required. I can make the welds now to some degree by using very particular methods, but again I want something better.
And, I don't have a clue how you would preheat a sheet 16 feet long and 4 feet wide. Weld inside a giant oven while wearing an air conditioned fire suit?
I recall what it was that I did with my gun that reduced burn back. I shortened the inner wire feed tube, and then rethreaded it so the tips would still screw in ok. I think the thread on the Miller forum (it might have been on the SEJW Usenet group) where they discussed that said you could cut it back as far as 1/4, but I only shortened mine about 3/16. The other two things I found to be critical for MIG welding aluminum with my gun was keeping the proper distance for spray arc (about 3/4 inch from the nozzle hood), and clipping the little ball off the end of the wire before every restart.
I didn't have too much fear of trying that since the replacement parts where rather inexpensive if I wanted to turn it back to the way it was. Even Miller name brand wasn't too bad, but places like USA Weld also have replacement parts for those guns. (Made in the same factory on the same production line.)
Given all of that I can't have any breeze at all on the immediate weld area or I get welds that look like I forgot to turn the gas on.
If your spoolgun is not feeding wire properly check the inner liner (on my gun it looks like a spiral wound spring) between the rollers and the nozzle, and make sure you are using the correct size rollers. Also, if you have a spring loaded thumb release for separating the rollers to feed wire in check to make sure it is working properly and fully snapping back to pinch the wire when you release it.
The problem is it builds to much heat in the weld area and drops out. On modest length welds you just have to walk away for a few minutes and let it cool. On longer welds you can do short 1/2 to 1 inch stitch welds every 6 inches or so, and then do fill beads between them. Then you go back and forth making your fill beads in alternating areas a couple feet apart. Its a very particular process, and it does work, but again.... I was looking for something better. Which was why I was looking at Pulse MIG. And I had the chance to burn a rather longish weld using a Miller 350P a while back that rather impressed me. I just can't justify the cost of a 350P.
I think I already said all of that earlier in this thread.
While I admit I am a novice welder, I am not asking (nor was I ever in this thread) how to weld aluminum with my Miller 212, but what rig other than my 212 (in my price range) might make it easier and faster and hopefully better than the process I have to use with it.
As to robot welding... Lets not assume that its not programmed to make current and frequency adjustments based on feedback. They don't just stick a MIG gun in a mechanical hand and call it a robot welder. LOL.
I'm certainly no expert at this but, it seems to me that if it "builds too much heat in the weld area and then drops out" you're using too much current (maybe to compensate for the "cold" condition of metal at the beginning of the weld). If the amps were set right for the "built-up heat" then the preheating at the start would make the material ready for that setting from the begining...
No?
What do you set the volts at? Frankly, it sounds like your procedure is right. Of course, pulse will help but walking away when the heat builds is SOP.
Your experimentation with the contact tip set back is compliments of the geniuses at Miller that decided you don't know better. Their 'Qwik-tip' is an abomination.
I just use the chart on the welder for speed and power settings, although I have found it likes a little more wire feed speed (not much) than is says on the chart for aluminum for almost all thicknesses listed. My experiments outside the listed working range of the gun have all been hit and miss, but extrapolated from the chart. I suppose I could try going colder and slower with a preheat. The only time I've done preheating before has been on 3/8. 3/8 is the thickest aluminum the welder is rated for, but it will NOT do a passable job without preheating.
I think I might have mentioned before that I can almost wallow around like you can on steel with 1/4" aluminum.
