Originally Posted by
agent4573
Yeah, you can do full throttle runs and tune that curve, but what about the 90% throttle runs? Or the 80%, 70% all the way down? On a carb, once you get the right size main jet with a full power run, the carb takes care of most of the tuning at all other throttle positions. Depending on the carb, you normally have 5 adjustments to make and the carb takes care of everything else; Float height, needle height, pilot size, main size, mixture screw. A simple FI system will have at least 10 RPM slots and 10 throttle positions to program. Thats 100 adjustments you have to make, which doesn't count any cold start enrichments, MAP sensor enrichments or any other inputs you're using to tune. You can easily do the WOT runs on the street and tune that, and you can probably do the no load conditions in your driveway, but everything in between is going to be a royal pain in the ###.
