I would say, the mild steel is more flexible for TIG welding. Aluminium cannot be welded without a filler rod (I cannot do that for sure), and one is very sensible for temperature, so you have to preheat the parts or you should use a pedal to control current. On other hand, I use to weld some tools made of mild steel without a filler rod using 2T mode and it really works.
https://lh6.googleusercontent.com/-7...0/IMGP0425.JPG
https://lh5.googleusercontent.com/-u...0/IMGP0435.JPG
