The fit-up must have been very good if you welded all that autogenously Ok are you trying to impress or confuse me with big words lol:O
No way Joe I do not want to get people making fun of me lol. I am not insecure or anything I just want valid input and not trolling remarks. Once I get really good with the EL Tig Ill post stuff on there and link it here to see what people say!
Wowowow Thanks Jakeru I didn’t even know what I was doing when I welded this! Autogenously welding is when you fuse 2 materials together without filler material (Wikipedia just now). Yeah this pipe will have almost no weight on it and it will be suspended by the engine there should be no stress or strain on it. And the pipes were cut from a wooden jig in a band saw I made. Then I sanded them until I couldn’t see any light between it and tape it togeather.
I noticed that I was able to move very fast after I got the hang of it. I figured out the angle that I should hold the torch and it was really easy after that. If I had to add filler I would have been very slow.
Thanks for the info on the solar fulx! All I knew is that it’s supposed to shield the weld so I don’t get that sugaring or chunky black stuff called Carbide Precipitation. I figured trying to back purge something small like this would be way too hard. I thought that black glassy stuff in the inside of the pipe was still carbide precipitation but its solar flux after it changed. It goes all the way around the weld so I guess I got it on the pipe pretty good! I scraped away the black glassy stuff and there is shiny metal underneath so I don’t believe I have any carbide precipitation at all. Thanks for the info Jakeru!!!!
Read this Cuda this is where autogeanously welding is explained I learned something new and I didn’t even know I was doing this at all!
http://en.wikipedia.org/wiki/Gas_tungsten_arc_welding
