3 coats of gun blueing? paint or a salt bath
Thanks for the kind words. dgarnier, I used a cold bluing, getting it clean enough to get an even coat was a time consuming process to say the least. This project is a couple years old now and the bluing has held up well.
This is BEYOND impressive, when will you start the full size version since you built the scale model already? HAHA Excellent work!!!
Look's like you all like this stuff so here's an update. I've been toying with ideas for a new metal car project and remembered an old 1933? Rolls Royce model I was given years ago. It's in pretty rough shape. That was the excuse needed to pick up a 6" rotary table for the 3 in 1.
http://microzone.us/weldgallery/d/47...side+start.jpg
http://microzone.us/weldgallery/d/47...+and+parts.jpg
http://microzone.us/weldgallery/d/47...le+-+small.jpg
Next post.......
Of course, I'm doing it my way (yes at one point I was thinking of a supercharger sticking out with tubs & slicks on the back). The stock wheels are pretty boring, and part of my reason to do this is to challenge my beginner machinist skills. The car is about 15" long, the wheel rim is 2", hub about 3/4". I'm using pins for spokes, 48/wheel (24 on the inside, 24 on the outside. Here's the pics:
http://microzone.us/weldgallery/d/47...heel+start.jpg
http://microzone.us/weldgallery/d/47...heel+small.jpg
http://microzone.us/weldgallery/d/47...l+hubs+002.jpg
Next post....
More wheel pics:
Needs to be cleaned up yet
http://microzone.us/weldgallery/d/4773-1/044.JPG
http://microzone.us/weldgallery/d/4770-1/040.JPG
http://microzone.us/weldgallery/d/4767-1/036.JPG
Got bored drilling holes, so I jumped to the frame. The original is toast but will work as a template.
http://microzone.us/weldgallery/d/47...45+-+small.jpg
http://microzone.us/weldgallery/d/47...46+-+small.jpg
I've since finished the front of the frame and patched up some of the body. I haven't snapped any recent pics, but will share once \i do.
Cheers!
holy cow man! that is a ton of detail! the steering works, the doors open...
does the suspension work also?
that is so bada$$!!
The 4 link does work but the springs are not spring steel and the shocks are solid, those pieces keep it from flexing properly.
