I use standard 1/4"npt quick connects on my PP256 and they don't leak at all. I have a female coming from the welder solenoid, a male for the argon bottle and two males (one in, one out) on the air pressure regulator. It's a very simple setup and works well.Quote:
Big bottles require a big cart. It depends on the size of the wheels and the design of the cart as to what size bottle can be safely used mobile wise. I planned ahead in case I wanted or needed to go to a larger size tank. The mod to my cart was easy to do. The 4 wheels each can handle up to 350 lbs. for a total of 1400 lbs. so with all my welders,cables and tanks on the cart the total weight is around 450 lbs. which has plenty of safety margin. My cart is 2 and a half feet wide at the wheels so it is plenty stable. The larger wheels roll over obstacles easily. I see no problem with rolling the 350 tank on the cart. The only problem I see is when I get older and the 350 or even the 250 gets to be too much to lift onto the cart. Lifting 170 lbs. of dead weight is not a problem right now, but in 20 or 30 years from now, it might be.
The other big thing is transporting the big bottles. The 125's fit perfect in the back of my car. The 250 I have to move my front passenger seat down and have the bottle hang into the front seat. The 350 is going to be a monster. It is heavy and it is big. But, it will save me tons of gasoline and cheaper to fill volume wise so it is worth the hassle to haul it back and forth from the LWS. $85 for a complete fill for three times the gas at $45 in my 125 is a no brainer. I will save $50 on gas for the 350 over the cost of filling the 125 three times. like getting a third 125 free!
Quick connect fittings I have heard may leak as they are less secure as a screw on fitting. Just something I have read somewhere else. May or may not be valid. I have not seen very many quick connect fittings for shielding gas so there must be a reason why they don't offer them. Automotive type quick connects always leak on me. The quick connect on my Powertig 250EX seems to leak a little. The direct connect on my Hobart holds the pressure of the argon / co2 forever while the quick connect on my Powertig loses pressure after a few hours. I have a direct connect barb from the regulator to the back of the machine and of course the quick connect at the front. Could be an internal leak or a leak right at the connector. Not sure. The leak is not enough to affect the weld so I just let it go.
