In the mean time I started closing up the rest of the openings trying to keep things from getting too far away from possibly looking OEM+
http://www.projekt6.com/jackal/Galle...d/100_3145.JPG
http://www.projekt6.com/jackal/Galle...d/100_3149.JPG
http://www.projekt6.com/jackal/Galle...d/100_3151.JPG
Worked on the wheel well.. This was actually interesting. The front of the wheel well lines up pretty close.. The rear was a couple inches from matching together but with some banging, it will fit together.
Welded.. I did have a problem with the rear of the wheel well wanting to burn holes even with my welder all the way down so I ended up getting it to weld though and the front seemed to work decent and I was able to turn the welder back up some and make sure it was burning in solid.
http://www.projekt6.com/jackal/Galle...d/100_3160.JPG
http://www.projekt6.com/jackal/Galle...d/100_3169.JPG
And patch the last hole.. Here you can notice my problem with the rear of the opening that I had.
http://www.projekt6.com/jackal/Galle...d/100_3171.JPG
http://www.projekt6.com/jackal/Galle...d/100_3172.JPG
http://www.projekt6.com/jackal/Galle...d/100_3173.JPG
http://www.projekt6.com/jackal/Galle...d/100_3174.JPG
http://www.projekt6.com/jackal/Galle...d/100_3175.JPG
http://www.projekt6.com/jackal/Galle...d/100_3177.JPG
And started a piece to fill the rear of the wheel well and fit it to the R floor
http://www.projekt6.com/jackal/Galle...d/100_3180.JPG
http://www.projekt6.com/jackal/Galle...d/100_3183.JPG
http://www.projekt6.com/jackal/Galle...d/100_3184.JPG
http://www.projekt6.com/jackal/Galle...d/100_3185.JPG
And keep the idea that I may need to remove the bolt there sometime..
http://www.projekt6.com/jackal/Galle...d/100_3186.JPG
And that is how it sits and I guess will sit until I can work on it again. Anyway I guess I am close to being able to say I have an AWD MK3 now :)
All the welding done in this update was with my MTS200s which I have only used for MIG but have found that it works well after the first initial complications I had while getting the machine setup. I have used a Lincoln Mig before the MTS and can't say that I like the Lincoln any more than the Everlast.
