There are 3 things that matter in any electrical installation, Breaker, (wire dia. size& length) and plug, The rule that must followed is: the breaker must always be the weak link. To get it right,,, you need to know your breaker size, the wire size and length of run and a proper plug or outlet for the amps.
use this calculator to checkout your setup.......... if you are near the limit of one wire size run, use a larger dia. wire for safety in your design.
http://www.gorhamschaffler.com/wire_...alculator.html
