First two days of welding Noobness!
Alright I am rather excited about this... probably a decade-long dream of mine has been to be able to weld... and since most of the projects I want to do are aluminum (intake manifold, aluminum exhaust, brush bars etc) I got my hands on my new 250EX. If I am going to be a noob again, I may as well noob it up on something ultra cool.
My welder arrived a couple months ago, and I have spent these months aquiring the remaining gear such as a nice Vika portable workbench (xmas gift from the GF), cutoff wheel, bench grinder, my own argon gas cylinder (a 22), 4-sensor auto-darkening helmet, and consumables. Most importantly, I read and read and watched many welding videos. Having never done any welding, I needed to cover all the basics. I perform in the music industry, so dealing with lots of knobs and foot pedals is familiar territory, thankfully :).
I cleaned up a heavy piece of 1/2" aluminum U-plate to use as a welding surface and protect my table, and used another piece of plate as a third hand.
http://members.shaw.ca/MKI.5_Overflo...rk_surface.jpg
Two evenings ago, I felt I was ready to have a go at it. Since I have tons of scrapyard aluminum tubing, and I will be working on intakes and exhaust tubing, I figured I'd get my practice in on tubing instead of flat sheet. After several hours of familiarizing myself with the settings on the machine, I had it dialed in pretty good. I ran lots of beads, and they went pretty well, all noobing aside. Last night, I attempted to join two pieces of tubing together, which was considerably harder than running beads. But, I got it figured out.
And tonight, I chopped half a dozen 1" bands of tubing, and welded my first pieces of tube together. I have to say I am extremely impressed with this welding machine. It was very forgiving. Considering I was using scrapyard tubing with a few burrs here and there, just a quick wipe with acetone on the outside, not to mention a complete noob, it gave me a beautiful arc and nice puddling. I am fully aware of the importance of correct cleaning... I was curious as to what I could get away with playing around with the AC balance.
This tubing is 3 5/8ths diameter, around .0508 wall. I am using 3/32" 2% lanthanated tungsten and 3/32 4043 rod. My settings are 60 amps, 7 lpm of argon flow and a #6 cup, AC frequency at around 135 and balance at about 50% (which happens to be right at noon for both).
http://members.shaw.ca/MKI.5_Overflo...Joint_weld.jpg
Starting the joint was the hardest part... what worked for me was to warm up both sides of the joint (but avoiding the seam), until I had a puddle started on each side and then just added filler and joined the puddles, kind of a "U" shape movement with the torch. If there is an easier and cleaner way I would be happy to hear about it. You can see the start-point in the pic below:
http://members.shaw.ca/MKI.5_Overflo...tart_point.jpg
Any advice, tips, thoughts are most welcome. I will keep adding to this thread as I tackle my intake, exhaust and manifold projects.
