Consumables on a Supercut 50P.
First of all hello everyone my name is Robert. I am new to this sight. I recently purchased a Supercut 50P. I noticed that when I first turned on the torch there was a perfect flame on the torch. After cutting a piece of 1/8 aluminum diamond plate when you turn on the torch the flamesputters. I noticed that the electrode is not round on the tip of it. It has a gouge in it now. Could that be the problem? Once you start to cut the sputtering of the flame goes away. My second question is would these consumables fit my torch. I have the red torch I believe it is the 60 amp torch. It has the pink ceramic cups.
http://cgi.ebay.com/25pc-60-amp-Plas...item4aa226a566
As far as the air pressure do you have to adjust the air pressure for different thickness of metal or just the amperage? Thanks for your time and I hope to learn as much as I can from this sight.
