I've decided to go with 2 ball valves mounted to my cart for the PP256 for switching between air and argon.
I was wondering if there is a certain rated ball valve I should look for?
3/8" should be fine
They have different ratings also some for natural gas, some for fluids, others for "general" and PSI ratings.
My main concern was if Argon could get past the seals.
What I was thinking was 1/4 as the internal passage is larger than what goes into the machine. I have one thats rated up to 250 psi, has a yellow handle, and has 600 GWP and 150 SWP cast into it.
Argon is heavy/dense. It'll sink in air. And its totally non reactive. I doubt you'll have any problem with any material rated for gas line pressure, particularly a metal/brass valve.
Sorry Slick I just saw your question in another thread, I've posted the response here as well.
Tony
http://www.mcmaster.com/
- 4112T23 COMPACT HIGH-PRESSURE BRASS BALL VALVE, 1/4" NPT FEMALE X MALE, LEVER HANDLE
- 50785K72 MED-PRESSURE BRASS THRD PIPE FITTING, 1/4" PIPE SIZE, TEE
- 5346K16 BRASS BARBED HOSE FITTING, ADAPTER FOR 5/16" HOSE ID X 1/4" NPTF PIPE
- 50785K43 MED-PRESSURE BRASS THRD PIPE FITTING, 1/4" PIPE SIZE, MALE X FEMALE 90 DEG ELBOW
- 50785K12 MED-PRESSURE BRASS THRD PIPE FITTING, 1/4" PIPE SIZE, NIPPLE, 1-1/2" LENGTH
