I'm building a cart for my new Lightning.
I'm interested in painting it the same color as the machine.
Does anybody know what spray paint company (rattle can) makes a color super close to the Everlast color green ?
Thanks.
Thanks.
No matches so far. But it is Pantone 355c if I recall correctly.
I can't believe nobody has found a close match..lol
Krylon ?
Rustoleum ?
Some farm implement color ?
Thanks for the response tho.
Did you know,,,, that you can take a panel to the Auto Paint Store and they use a camera that analyzes the color really closely. THEN, at least the one I goto, they can mix the right color for you and put it in an Aerosol Can!!!
For like $25.00
Gee, Blaster,
If there is no off-the-shelf solution locally, then your Auto Paint Store is the elegant solution, for those who can find stores like that nearby!
Otherwise, with Mark giving the Pantone 355c quote, spray cans for that can apparently be found online for around $20, or less:
https://www.myperfectcolor.com/paint...ol-spray-paint
If you were going to powder coat the part then RAL 6018 is the powdercoat number. I found a color that's from Valspar paint, but couldn't find a good picture. The Valspar Paint number was 65036 Garden Green. The RAL 6018 powdercoat is the color thats on my MTS 251si, MTS 221sTi and my 52i Plasma Cutter (not sure about the Lightning). I got the RAL 6018 from Alex at Everlast.
I wasn't sure if it was the same as the new machines, just thought I'd throw it out there because it matched perfectly to my 52i (and my 2 MTS welders) which I made some brackets for.
