I recently purchased a MTS 275 that has an intermittent problem, it does seem to be becoming more frequent. I'm welding 14ga 1 1/4" tubing with .030 wire 290 WS and 17.5 to 18 V . It will weld perfectly and then with making no changes will not weld. It stutters and has a hard time establishing the puddle and maintaining an arc. As I said nothing changed ground still in the same place and on clean metal. I did find the grounding strap loose from one side of the cable clamp and fixed that and thought I had found the problem however it came back after just a couple 1" welds. Replaced the ground clamp and cable with one I had on a stick welder this clamp was a hobart t-style and did not fix. Mark has suggested that I could have a bad roll of wire or may need to change the liner, running the yellow liner that came with the 10' MB36 gun. It does not seem to me to be the problem I can immediately pick up the mig gun and wire feeds fine very smooth and no jerking of the wire roll. I set the wire speed to 300 and pulled the trigger and ran out 29" of wire in 6 seconds which is 290ipm really close to setting considering lag in pre-flow setting. I videoed the weld and will try to attach the camera didn't pick up what was going on with the wire but you can tell more about the sound. Also videoed the control panel and WFS/A is jumping all over the place. I have not tried the stick or tig function yet. Video will not load will link a YouTube file.
Video of the weld: https://youtube.com/shorts/KrUMZ6s7TBI?feature=share
Video of the control panel: https://youtube.com/shorts/golqiN5KczY?feature=share
