Hi, With my all transformer mig I used to adjust voltage high enough to get the heat range I wanted and adjusted wire speed only fast enough that it would not melt off if globs. With my newish 140e it's more of the oppsite. I can have the voltage quite low and run a lot of wire speed. Also, the arc seems weak at a low enough wire speed just above melting off in globs.
How should I set up an inverter mig?
Thanks in advance!
