TIG only vs MTS
Im deciding between getting a TIG only (like the 325ext) and a MTS 275. I have a small 220v MIG already (Hobart 180amp). MIG on the MTS has more features than my Hobart, but I probably would only use the MIG for steel once I have a TIG. So, is worth losing some TIG amperage to to have slightly better MIG if I?m only using the MIG for mild steel?
Even with the TIG, I will still mostly use it on mild and tool steel. Occasional aluminum. Most of what I do revolves around forging steel.
Thanks for the advice
You are really not loosing anything. The 275 would have more power than you'd need for anything you'd tackle imho. If you want one, give me a call at 877 755 9353 ext 204. They are in stock but the 325's are out right now, and the ports are backed up for weeks.
