200DV Amperage requirement
Good day all
I acquired a 200DV welder and am in the process of organizing and installing power for it.
Manual doesn't state what it needs for circuit amperage.
What size breaker does one need for the welder both 240 and 110?
I emailed Support but their answer for 110/120 does not make so I am suspicious of the total answer.
They stated it would need a 30AMP breaker for both 120 AND 240. Makes sense for the 240 but not the 120.
The supplied adapter for 120 is a standard 15AMP plug. They are suggesting I use the supplied 15AMP rated adapter cable to plug into an outlet rated for 15 AMPS, but stating it needs a 30 AMP breaker which needs 10 gauged wire. Well that's just .....
The documentation they gave me says I can plug into any "standard 120 volt outlet using the adapter available separately".
Well I'm pretty sure that if I do that and they say I need a 30 AMP breaker for 120, the results won't be pretty. Worse if someone says "Oh, I need to replace that 15 AMP breaker with 30AMP one before it will work".
Yes I know you can't run a 30AMP breaker with 15 Gauge wire, needs 10 guage.
So, as Everlast says I can plug this unit into any "standard 120 volt circuit", why is it they say I need a 30 Breaker for 120 usage? That's not certainly not standard and it's also certainly not "anywhere".
I've tried calling them but no one answers the phone.
Thanks all.
