PowerPro 205(~2010), low power in Tig mode, too low to weld.
I've search over the forum, but the few threads that seems to be like the problem I got doesn't finish with a solution. So here what my machine do or don't :
-Stick and plasma work.
-Amp power knob work in those mode.
-I can stick weld with an electrode in my tig torch(so I can assume that my tig torch and my ground clamp are good)(I have try 2 different torches and I have disassembled the ground too) .
-It does the problem with the trigger on the torch or with the pedal.
-The hf works,(it buzz before it start the arc)
-The arc start, but the amp on the machine stays at 23amps with the trigger is activated. The amp meter still stay at 23 even if I just trigger it but stay away from the table.
-For an obscure reason the machine start working again for about a couple of minutes (after 2years of break before I tried it again last week)
- It does that in ac and dc, and with whatever settings I try(more pulse amp, more or less amp, flow, slope...)
Any input or test you have in mind to help me.
