Water cooled 200DX aluminum issues since new
Ok, I bought my 200dx setup about 2.5 years ago. For the longest time I did not have 220 in my garage so I ran the welder on 110. I was do9ng a lot of thin stainless and some thin aluminum tubing. Welds great onstainless, but the aluminum, it always has struggled to keep the arc going until i dab filler rod. Once fuller is applied, the arc is nice and smooth. Before filler is added, i can hear he machine making the noise it makes if you were told hold the torch in the air and hit the pedal.. the buzzing noise. It's like until filler is applied, it is not getting a good solid arc. I thought it was because I was running it on 110. I recently got 220 service in my garage and it is the same outcome. I weld a ton of aluminum at work, but with a precision tig275. My inverter is a lot different at home. Anything I can do to fix this? Also, why does it happen, and is it normal? Thanks
