Power Ultra 205 Plasma amps not correct
Hello,
I bought a Power Ultra 205 Multi Purpose welder in 2011.
I used it about 5 times and then boxed it and moved.
Last year (2016) I decided to set it up again as I needed the Plasma cutter.
When I tried the unit the Plasma function itself worked and I could cut metal.
The problem is that the amps will not go below 95 at the min setting and will go to 237 amps at the max setting.
The stick amps will display 004 amps and will go to 202 amps.
I have emailed Mike K at Everlast who suggested that the display is incorrect and I could simply just adjust the pot for the display and dial it back down.
I am just wondering why or what happened to this welder to cause this.
It is a hobby welder and rarely used.
Any comments or suggestions would be appreciated.
Thanks.
I have a video of what the display panel is showing and here is a link to it.
https://youtu.be/l5ahMjoON1w
