Hey gang,
So I tried really hard to buy an AHP 200DX, but getting one shipped to Canada turned out to be a bridge too far. So a picked up an Everlast 200DX instead.
I'm teaching myself how to weld aluminum. I have a couple of specific jobs I need to do, and this is a capability that I have always wanted.
I was running linear beads on plate with surprising success. Attempting to weld a 0.40 block to the plate was more of a mess... but Rome was not built in a day nor should I expect to master this in a couple of evenings.
Then one night, suddenly I can't run a bead. Filler balls up and won't flow into the puddle, the puddle itself seems dirty... just a mess. My first thought was that I'd run out of argon, but there's still plenty in the bottle.
Then I discovered that while the foot pedal was lighting off the arc, it wasn't tripping the gas solenoid - but intermittently. And when it was triggering, gas flow seemed less than I expected.
Then the pedal stopped working - until I figured out that if I pushed the pedal down, tipped it forward, and then let the back down with a "clunk", the impact would open the solenoid and light off the arc. Then the pedal would respond as normal until I shut it off. Then no more response until "clunk" again.
I ordered a replacement pedal from SSC Controls, and we'll see how that works - but the OEM pedal went wonky after maybe 6 hours of use.
