I am interested in purchasing your PowerPlasma 50 Model and I have a few questions to ask. I was currently using a Hypertherm MAX-20, but the transformer went on me and I don’t think its worth the cash/time to fix a 20-30 year old machine that cuts at 20 amps max 3/16” thk.
Here are my questions… for now;
-What is the length of the torch cable?
-I am buying this for use with a CNC plasma cutting table. In order for the PC to control arc on/off, I would need to zip tie the trigger closed, splice into the wire that runs to the trigger and wire it to a relay, then run the wire back to the trigger. This way when the PC closes the relay, the torch trigger is already closed and the arc will fire. Will this void the warranty of the machine? Is there another way to do this with this machine?
-What is the voltage & amps that the torch trigger operates on (not the plasma itself). The relay I use is rated at the following.
- Maximum Current (AC) 7A@240VAC; 10A@125VAC
- Maximum Current (DC) 15A@24VDC; 10A@28VDC
Thanks for anyone the help!
-Chris
