old (2011) 200 DX: no panel amperage control for the footpedal, options?
Hi all,
RE year 2011 200DX machine
I know this has been answered a million times, but most of the advice for this old machine is also very old and there may be better options available now.
I want to TIG very thin metal and fill rust pits on antique gun barrels and so I want to experiment with low amperage settings. I would like to use the foot pedal, but on this old machine maximum amperage is set from the footpedal's rheostat and not the from the 200DX's front panel. But, the rheostat settings are really only a relative index of amperage and not an exact measure, plus, the heat output in response to the pedal numbers is very non linear: at a setting of "7", nothing much happens, but at "8" you get almost full power (at least on mine).
I'm assuming that to get panel control over the footpedal I would need to get a new machine, so the answer for me, I assume, is a better footpedal. Any new good ones that would fit this old machine, or barring that, a pointer to a do-it-yourself job?
Thank you in advance.
-thirtyforty
