Bad gas? Or leak I can't find? Not to sure, anytime I try to run a bead I start with a clean electrode, sharped parallel to the tungsten rod. I was going to buy 2% lanthanated but they didn't have it so I bought 2% ceriated 3/32". The machine is a brand new Everlast250EX and everything I'm using comes in the box. New 80cu/ft bottle of Argon. I have stayed away from foot pedal so far. Torch is in (-).
Metal has been mild steel 3/16" square tube, just running beads on one side, sometimes with filler. Filler is er70s2.
I have the tried gas from 5-40cu/ft/hr all with similar results. HF start works good almost always. I'm holding the torch about 3/16" from surface, and at about 15-20deg angle. I hear the purge of gas when I light off. I've put soapy water around line connections that I can see and no bubbling. I clean the tungsten and the metal ground off shiney with acetone.
So for now I'm lost. Mostly I've been trying in the 80-100amp range. I had some thinner plate I tried at 60Amps, all looks the same.
I've also tried some 3/16" aluminum plate on AC and it was pretty much worse then the mild steel. I couldn't even get filler to add to the crappy puddle.
Any thoughts? Can I open the machine to check for gas leaks inside?
My only somewhat decent bead. Still horrible
http://imagizer.imageshack.us/v2/800...912/4SQPL3.jpg
Most look like this
http://imagizer.imageshack.us/v2/800...913/dHYECh.jpg
http://imagizer.imageshack.us/v2/800...913/dK7lD5.jpg
Heres the tungsten before a spot test
http://imagizer.imageshack.us/v2/800...913/b3B2x4.jpg
Here it is dirty after a 5sec light up and 10sec post flow.
http://imagizer.imageshack.us/v2/800...633/STxbHL.jpg
Heres some spot test, one on the left I had it lit for 10 seconds.
http://imagizer.imageshack.us/v2/800...901/Wv4nyn.jpg
