PowerTIG 185 questions.
On my older model 200DX, if I plugged in the foot pedal, I didn't have a way to set the amperage at let's say 100 amps. If the pedal was plugged in, it would go all the way to 0-200. And I couldn't set the amps at a certain amperage, and the amps wouldn't go past that.
On the PowerTIG 185, is it the same way? Or can I set the amps, and with the pedal pressed all the way down, it won't go past it?
Did you get my email? To sum up: The 185 and the 200DV(DX) maximum amps are set on the panel.
I did thanks. Just wanted to make sure before I picked one up.
