Power Ultra 205 amperage throttling fail
I have an older model but I have kept it in great condition and have only used it on few occasions. What I have noticed is that when Tig welding with the pedal the amperage will not modulate up or down. If you turn the potentiometer inside of the pedal, the the amperage will display from low to high as you turn the pot. As soon as limit switch is activated amperage no longer modulates, This is not a pedal problem, can anyone help me out, I am a electronic tech, I could probably figure this problem out if I had the schematics?
