Plasma stopped working on PowerPro 205
I was using the plasma cutter on my PP205 and it suddenly stopped working. I had made one cut about 10" long through thin sheet metal. Started another cut and it would shoot a single hole through the metal and then stop. I would try again and get one blast and then it stops. Did that about three times and then nothing. I replaced the tips on the end of the gun and still nothing. Checked for a good ground but still nothing when I pull the trigger and strike at the metal. I don't see anything unusual on the display and hadn't made any changes right before the problem.
Am I supposed to still get air blowing through when I pull the trigger even if there is no arc? Nothing happens when the trigger is pulled.
I've used it several times in the past for sheet metal but probably for less than 20 cuts.
Any ideas?
