What are the benefits and drawbacks of each welder
I'm not much of a welder myself but I need a shop welder for a small machining and fabricating business. I want to buy a welder that will handle most kinds of work and have been asked to weld most common metals from mild steel to aluminum and copper. Assuming I hire a welder that can actually use the machine to it's capacity, what are the benefits and drawback of the 200DX-D and the 255EXT, why would you pick one over the other if cost isn't a major consideration? Is there enough of an advantage in the EXT to justifies the extra $1000?
LaVerne
