I-Mig 200: This is a good welder!!!
		Some years ago, I had a Powcon 200 that I really liked, but it didn't have a built in wire feeder.  I promised myself that if anyone ever came out with an affordable inverter based welder with a feeder built in, I would buy it.
The I-Mig 200 has not disappointed.  It has a nice arc, easy to set up and use, light enough to carry aboard boats I work on, and best of all, it has one of the greatest advantages of an inverter welder - it requires less primary current for a given weld output.  I have a Tig outfit also, but Mig is faster and perfectly adequate for many tasks.
I held off buying a Chinese manufactured welder because of the reputed failure rate of some of these units.  However, Everlast claims to have addressed this problem with their IGBT technology. Time will tell, I guess.  But so far, I'm loving it!!!
If this unit is any example of what's coming out of China these days, then Miller, Lincoln, Esab and Hobart had better watch their backs.  They don't make anything in this price range that can compete directly with this welder.
If this welder or any in their line fills the bill for what you need, you should try it. With their return policy, Everlast make it easy.  That's what cinched the deal for me.
		I-Mig 200: Further comments
		As I understand the specs, the I-Mig 200 requires a 30 amp, 240 volt power supply for full output. Since I didn't really have time to rewire a receptacle in the shop, I've been using a 20 amp outlet and haven't popped a breaker yet while running .035 hard wire with C-25 gas (short arc).  I've not   tried .045 yet as I haven't done anything that needs it. I really like flux cored (dual shield) wire, but I am still waiting for Everlast to get the flux core drive rolls to me. Dual shield wire (use with gas) really makes beautiful welds and makes me look a lot more competent  than I really am. The material has to be fairly clean to use this though.
I put an adapter on the gas inlet to convert to the standard AGA weld gas fitting.  Makes things a bit easier when changing bottles or breaking down and reassembling when moving this unit around.  Thinking about  putting weld gas QD's (quick disconnects) on.  They're similar to air line fittings but don't leak at all.  Also got a Smith regulator so I could read CFH directly.  None of this was necessary but I like to trick out my machines a little.
The Binzel gun was a surprise.  I was expecting something super cheap, but the Binzel is very comfortable, sort of like the Bernard guns.  The 11 series Tweco contact,tips fit perfectly, so it's easy to get those.  The gun is only 10 feet long, but it has never been too short for me.  Actually, for a rig with this kind of portability, the shorter gun makes for less to coil up when moving around.  It seems like a lot of thought went into designing this machine.
The wire drive is easy to adjust, and the drive rolls not that difficult  to change.  I particularly like the spring loaded idler roll bracket, because it stays out of the way while feeding wire through.  I would prefer gear driven drive rolls where the powered and idler rolls are geared together for a more positive wire feed, but so far the wire feed has been consistent and  posed no problems.
Nits? Sure, but nothing much worth mentioning.  No machine is ever perfect, and "perfect" is different for everyone.  But I can't really think of any machine on the market that would give me more of what I want than this one, especially at the price it's selling for.
		Mig a good place to start
		Thanks Mike and Mark.  I couldn't agree more.
While I'm new to this forum, I have read others and get the feeling a lot of people try to learn to weld on a Tig machine.  That seems like learning to fly in a supersonic jet fighter.  Yikes!!  Were they to back down a notch and try Mig first, they would have an easier time learning and get some worthwhile work done in the process.  As they say, "Nothing succeeds like success."  Mig gives you the opportunity to build your confidence and skill at an easier pace, IMHO.
I have had very little formal education in welding, but fortunately I started out with a Mig machine and learned from that.   There are literally thousands of little lessons that can be learned that way which keep adding to your skill and safety level, and when you're ready to upgrade to Tig, it's a much smaller and easier step.  Also, again IMHO, it seems to me that a lot of the problems posted on the Tig forums would have been self-resolved had the weldor cut his teeth on a Mig machine first. For those who want Tig and can't afford both, it's been my experience that welding machines sell very rapidly in the classifieds or ebay, if they are in reasonably decent shape.
In my experience, there are not that many jobs that can be done with Tig that couldn't be done adequately with Mig.  Yes, Tig is extremely versatile, but for normal, everyday, meat and potatoes welding, Mig has done very well for me (and I have a Tig unit also).
I'd like to see some other experienced Mig weldors jump in here with their comments.  We could all benefit from them.
