i have some mig wire (lincoln super arc l 56) can i use it as filler for tig welding steel?
Yes. If you are making an open butt weld, just remember to keep your gap tight and your amps low. For fillet welds, just keep in mind that you will be feeding a lot wire because of the diameter of the wire you are using.
Generally, yes, it shouldn't be a problem, especially if the TIG wire has an equivalent number assigned to it.
how much cfh of argon do you reccomend?
I routinely use MIG wire for TIG on thin gauge sheet steel. Works well and isn't the nightmare that wrecks your puddle like 1/16" is. I'm sure it's mentioned here on the board elsewhere, but if you need a thicker diameter, you can double it over and make a "rod" with your drill & a vise.
I use the .035" MIG wire when doing sheet metal work (automotive sheet metal repairs and such). Wiping any wire down that comes off a spool is a good idea. A lot of times I forget to wipe off the "normal" TIG wire that I buy at the LWS, but it is a good practice that I am trying to get in the habit of doing! Obviously if you're welding really thin material, you'll want to get that tungsten sharpened to a needle point, otherwise you can wind 2 or 3 strands of MIG wire together to produce a thicker welding rod for heavier material as others (above) have mentioned.
