Hydraulic Tool Bender Build
Hey folks, just wanted to share with you a Hydraulic tube bender I built over the winter. I did my research and found that this bender would suit my needs perfectly and what better than buying a tool, then building one. Here is the link if you are interested in building your own. You will need to buy the plans for around $18, but from there it is relatively inexpensive to do the build if you have the skills and or tools and patience.
http://www.gottrikes.com/Tube_Bender.htm
Enjoy
This is the largest hold needed drilled, 1 3/8"
http://i159.photobucket.com/albums/t...7-10_741-1.jpg
after drilling
http://i159.photobucket.com/albums/t...-23-40_318.jpg
http://i159.photobucket.com/albums/t...3-48_545-1.jpg
the swing arm, now unfortunately for me, this one was off an 1/8th of an inch due to an error on my part, so I actually made a 2nd one. This pic is of the 1st one.
http://i159.photobucket.com/albums/t...8-20_944-1.jpg
http://i159.photobucket.com/albums/t...5-35_560-1.jpg
1/4" box steel
http://i159.photobucket.com/albums/t...-05-45_409.jpg
http://i159.photobucket.com/albums/t...7-19_256-1.jpg
http://i159.photobucket.com/albums/t...7-25_626-1.jpg
