I have these for sale on Ebay if anyone is interested.
http://www.ebay.com/itm/Everlast-Tig...item20cfe3c4a3
Chris W.
Chris W.
Do you know where I can find the Female connectors of these? Im in the process of building a weld cooler, I want to buy these from you, but only if i can find the females also. Where did you find these connectors?
Im not sure about female fittings, but Ill check into it cad see what I can get.
updated auction
http://cgi.ebay.com/ws/eBayISAPI.dll...m=140931359516
Maybe able to get these,
Its a bulkhead style fitting and it uses the 9mm male fitting that I sell.
http://www.aixia.es/site/ficha.asp?idp=1087&to=0
you can buy the female part of the qd from maryland metrics .com. Just google it. You can also buy the 9mm male plugs there too (cheaper than what 70Mav is selling them for on ebay). Last I heard they were about $1.25 a peice for the male part but you had to buy 10. You can also get both from weldingdirect.com. But the parts are more expensive at welding direct (17.99 for the female part, 3 something for the male part, $50 minimum order). At Maryland metrics dot com you can also get colored qd's if you want. The maryland metrics stuff is from the parker 2012 catalog. Good luck.
I went to the maryland metrics site, and could not find them. Very difficult to navigate.
http://mdmetric.com/rectus/products/...ka/default.htm
Rectus 21KA Hose Barb (brass) p/n 21SFTF05MXX
AJ Newman
